Cant post in 'for sale' section, but have one for sale!
R reg 1998 dturbo, ph2, white 3door.
143k
MOT end of Sept
TAX end of Aug
Car has had:
-Clutch & cable @ 133k
-Bottom arms, droplinks, track rod ends, rear axle bushes (x4) & handbrake cables @ 132k
-Replacement axle (drum brakes) @ 125k
-Battery @ 125k
-Cambelt @ 120k
-Idle tensioner & aux belt @ 135k
-Brake Pads @ 143k
Probably more if I can remember!
Car needs:
-Has 2 keys. One for the ignition, and one for the door locks.
-Possibly an engine mount (wobbles slightly under sudden acceleration/decelaration)
-N/S top mount bearing (clunks on lock-to-lock occasionally, had O/S done already)
-Roof aerial missing
-Boot carpet missing
-Driver footwell leaks in very heavy rainfall
-ABS not working, bulb appears to have been removed?
-Cosmetically not perfect. Small crease above the (missing) side repeater on driver's wing & a few tiny burn marks here and there etc. Bodywork is otherwise reasonable apart from minor blemishes, still shines up ok after a polish.
Selling this on a "spares or repairs" basis as it needs work doing. I've listed every single thing I can think of wrong with the car, as I'm not out to deceive anyone.
Offers? PM me!
(will try and post a few pics later)
We're are you located
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Forgot to add, running a Stage 1 tune done by the 'derv doctor'
(04-06-2013, 04:44 PM)karl1989 Wrote: We're are you located
Rochdale, in Lancashire if you're unfamiliar...
You need 10 posts. There is a thread at the top that explains all this.
If i were a mod i'd be getting rid of the ad for now tbh. Rules is rules...
(04-06-2013, 05:05 PM)cwspellowe Wrote: If i were a mod i'd be getting rid of the ad for now tbh. Rules is rules...
But you're not so pipe down pellowe! Haha
But yeah guess he's right
That's two people today that have said "...but i guess he's right"
Pellowe4Mod. It makes sense.
You need 10 posts to use the for sale section for a reason, you also won't be able to receive PM's for the same reason. It doesn't take much to join in and be able to do it properly.
  Hello and PM/for sale help Paul_13 9 4,249 20-10-2013, 09:33 AM
Last Post: Nick306td
  Any 306 hdis for sale Lincolnshire? Coops69 4 2,891 04-08-2013, 03:40 PM
Last Post: kingy
  As any 1 got a t2 turbo for sale cj_pug 1 2,076 23-03-2013, 04:30 PM
Last Post: EddB
