Leaking filter housing
I think i have a leak on my fuel filter housing down the side there is a white cross. What is this for as i also goes along the inside of the bottom of the housing and is it ok to block it up?
Cheers
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Isn't that to drain it?
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
No thats on the front this is a white cross sticking out the back side
Blaze 1.6 Dead
ping the metal retaining ring off it mate and it will just pull out with some pliers, renew the O ring and reassemble . . . . .no worries you can suck me off later . .Big Grin
Cheers cheesey Tongue
Any info on the penny trick i have read up about also?
Blaze 1.6 Dead
(03-06-2013, 03:44 PM)HDIkyle Wrote: Cheers cheesey Tongue
just posted in other thread . . Smile
^^^^ me to
  Filter housing replacement weka 2 3,307 25-08-2017, 06:16 PM
Last Post: weka
Exclamation Swarf In Fuel Filter Housing jordanhdi 11 6,589 26-09-2016, 11:55 AM
Last Post: pug306driver
  Removing the fuel filter housing, but what is this behind it? Iaitoo 2 3,257 27-04-2016, 05:33 PM
Last Post: Iaitoo
