Remove amour from Bosch pump
Any idea's?
Wanting to increase the fuel and thanks to this forum and some very helpful guys on here I know how. However my Bosch pump has amour on it and needs removed so I can get to the max fuel screw.
Anyone done this without removing the pump from the engine???
Attached Files Thumbnail(s)
ermmmmmmm . . .lol
That allen bolt there looks something to do with it?
Is this in a 306? I didnt think any boschs had armour :/
is that deffo a Bosch? . . .
(01-06-2013, 06:42 PM)Tom Wrote: That allen bolt there looks something to do with it?
No it's a Fiat ducato 1.9td. Think it stops thieves getting to the stop solinoid. Either way it's stopping me from going faster....Angry
cdn2.newsok.biz/cache/w620-aeecc44ddaf0d5be0a54d19398b255f7.jpg
its not actually a 306, but there must be something I can turn........
Some of these pumps have the bolt heads filled in, a right bastard to get off if that's the case.... Lots of stainless steel cutting discs required! You may aswell change the distributor head when going that far :p
That's a pump off job if they're filled! Sad
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
I de-armoured a Bosch pump from a 406 and it wasn't too bad but I couldn't have done it on the car. I hammered the security bolts loose with punches and a hammer. The last one was surrounded by armour though so I had to break out the angle grinder to get access to it.
  How to remove pulley from steering pump leswoollam 1 978 26-06-2021, 10:52 AM
Last Post: Mighty306
  How to remove pulley from steering pump leswoollam 0 738 25-06-2021, 02:51 PM
Last Post: leswoollam
  Slack in bosch pump? dt_ 14 3,467 21-10-2020, 03:41 AM
Last Post: dt_
