Clunking from nearside wheel
Got a clunk from the nearside wheel when held at 9 and 3 its a noticable movement and noise when setting off and stopping also.
Had new bearing, balljoint, wishbone bushes, droplink, TRE, disc, pad and top mount bearing.
What else can it be i dont think it does it on the offside wheel
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Ovalled hub? Thats all i can think of :/
No there fine Checked em when i had them shot blaster had new pinch bolts also its not movement in the balljoints but i dont know where else it can be from
Blaze 1.6 Dead
drive shaft id say. mine did it
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Will try that then was a second hand one from the spares pile
Cheers
Blaze 1.6 Dead
think i got a drivers side one
Ph3 perv cab heaven
Black ph1 XUD died
Passenger side mine. Short one
Blaze 1.6 Dead
Right, changed shaft and its still there. Checked all bolts and everything's fine. Also nipped up the top mounts on the shocks but there fine. It seems to be play in the steering rack. Its had new TRE but it seems to be movement in the rack. Steering is tight as when driving it does clunk the wheel when stopping and setting off.
Can the bit that holds the track rod to the steering rack cause this kind of symptom if they are worn? Easy to replace?
Blaze 1.6 Dead
This could be the problem never known anyone have to replace one on a 306
[Image: null_zps510692b8.png]
www.prestige-auto-care.co.uk
Know what? Im getting the exact same thing, and steering sometimes wanders. Cant find play in ANYTHING so mighylt crack off the tre and check for play
Ye thats what i was thinking seen them for £16 on ebay looks same as that tho. Easy to get to on the car to check?
Blaze 1.6 Dead
  clunking and rumbling? JTaylor2005 5 3,022 22-09-2015, 05:38 AM
  knocking/clunking Markie 7 5,837 11-07-2014, 02:39 PM
Last Post: Markie
  Rear nearside knocking, what is it ? DavidA 13 5,890 25-05-2014, 12:52 PM
Last Post: DeeTurbo
