Different ways of lowering a torsion bar..?
#31
Right just phoned pug and it seems they can do it cheaper. I'm going for the pokey method do what seals should I buy?
Was going to get the bearings and inner seals. Anything else?
[Image: Foxy2.jpg]
Foxy-jim Wrote:Right just phoned pug and it seems they can do it cheaper. I'm going for the pokey method do what seals should I buy?
That ebay link has everything you need:-
Outer Bearings x 2
Inner Bearings x 2
Crossmember Seals x 2
Outer Seal Cups x 2
Suspension Arm Seals x 2
Crossmember Seals Ext x 2
Torsion Bar Studs x 2
Eccentric Washers x 2
Torsion Bar Torx Bolts x 2
And I doubt you can get all of that from pug cheaper TBH!
Team Orange Engine Bay
What bits do I essentially need stuff like offset washers can be reused. How easy are the bearings to get out?
[Image: Foxy2.jpg]
Foxy-jim Wrote:What bits do I essentially need stuff like offset washers can be reused. How easy are the bearings to get out?
Sorry, yeah they can but for the extra they will cost is it worth not changing them??
things you really should change :-
Outer Bearings x 2
Inner Bearings x 2
Outer Seal Cups x 2
(so all the actually expensive bits and all the seals)
And I have never done it but will make the assumption that they will be a bitch being a fair way down the tube to the inner ones!
Fair enough. I may just bite the bullet and buy it.
[Image: Foxy2.jpg]
Done it! Chucking myself in at the deep end now haha. Hopefully I can do it!
[Image: Foxy2.jpg]
Good luck your going to need it haha
[Image: mintsig.jpg]
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04 Big Grin
Foxy-jim Wrote:Done it! Chucking myself in at the deep end now haha. Hopefully I can do it!
You will have a job unless you have a bearing puller/press I would think mate!!!
I've got a guide written by welshpug and he said he bashed the old ones out the hammered the new ones in!
[Image: Foxy2.jpg]
Foxy-jim Wrote:I've got a guide written by welshpug and he said he bashed the old ones out the hammered the new ones in!
Crack on then, just saying! :roll:
No need for a press/puller to fo the beam, just some big scokets, hammer and threaded bar with some washers for the inner ones. The outer ones will come out with a screwdriver.
[Image: sig.jpg]
Do you know the biggest socket I will need?
[Image: Foxy2.jpg]
Nope, not a clue.
[Image: sig.jpg]
I have a 26mm as the biggest. I think I read 32mm but not sure if that is for the hub nut of not?
[Image: Foxy2.jpg]
Na lot bidder than that, were talking like 2" across the outside of the socket.
[Image: sig.jpg]
Oh...is it essential or could i use something of a similar shape?
[Image: Foxy2.jpg]
Anything that fits in and will rest on the outside race of the bearing will be fine.
[Image: sig.jpg]
Awesome, Im sure I can find something. Hope this works!
[Image: Foxy2.jpg]
Jim did you take step by step picys to make a guide for this?
I didnt but I followed a guide on club-306! To be fair its pretty easy to do!
[Image: Foxy2.jpg]
Foxy-jim Wrote:I didnt but I followed a guide on club-306! To be fair its pretty easy to do!
Is there one on there? im off to have a look as i need to do all 3 of my 306's and im not looking forward to it Sad
Ye in the suspension section. Its a sticky. Use the one by welshpug! Where abouts are you based and when you doing it? If im free i could help.
[Image: Foxy2.jpg]
Im in calne on the other side of chippenham which is on the other side of brizzle, prob looking to make a start with the dt sun/tue
Fair enough. Im back home over the weekend and next week, not in Bath. Which way you going to do it?
[Image: Foxy2.jpg]
well Dt im not to fussed, but xsi and gti have to be done properly, gti should be ok as its been out before
I'm pretty sure I did mine properly. Pulled all the bars apart then put it back together just lower!
[Image: Foxy2.jpg]
have yours been out before though?
3 years ago on the gti the beam was on before.
[Image: Foxy2.jpg]
was it greased the 1st it was pulled? pug dont grease them when new hence the tightness
Im guessing so. But it took 3 hours to get the front plates off!
[Image: Foxy2.jpg]
  Lowering a torsion bar, nick method... GP123 28 16,655 22-09-2021, 11:06 AM
Last Post: Alan_M
  torsion bar lowering south east? connorp 1 1,157 26-02-2016, 10:43 AM
Last Post: toseland
  Torsion bar lowering Porty 4 1,616 14-01-2016, 08:05 PM
Last Post: Porty
