which ball joint?
Which size ball joint do I have? Ph2 r reg td estate...
2000 2.0 HDi Estate
The only size?
16 or 18mm
2000 2.0 HDi Estate
measure them you could have either Wink my GTI6 Ph2 1998 has 16mm
(21-05-2013, 07:04 PM)cully Wrote: measure them you could have either Wink my GTI6 Ph2 1998 has 16mm
Which is what I've always said... Phase/year doesn't seem to matter
Ok thanks. Thought I might be able to save a bit of time.
2000 2.0 HDi Estate
Never try and save time, just bites you in the ass
(21-05-2013, 07:45 PM)Connor Wrote: Never try and save time, just bites you in the ass
sooooooooooooooo true!
  Ball joint/ Hub to strut pinch bolts Uberderv 7 5,550 04-01-2018, 11:40 AM
Last Post: Mighty306
  fitting a front suspension ball joint impotentials 3 3,845 29-10-2016, 05:46 PM
  Bottom ball joint sizes Xsikid 4 3,690 04-05-2016, 05:45 AM
Last Post: Paul_13
