1.9 lumpy startup from cold and blue smoke!
Hi everyone
as per title really, when cold in the morning, fine to start, but when she fires up theres a fair bit of blue smoke for a couple seconds and also it sounds like shes running slightly lumpy.
After a few minutes its fine, the smoke goes, also runs smoother. No problems when warm, and no smoke when driving.
Cheers, Andy
I get this too. May be your glow plugs. Or maybe injectors...
Ive recently had new glow plugs, changed fuel filter too. So im guessing its injectors from all that veg I ran lol
When was the last service?
shes been serviced regularly but not for about 18 months now i think, however she only has 40k miles so shouldnt run rough or struggle to start surely??
Could just be glowplugs. Might of only done 40k miles but it might not have been properly care for in that time.
(15-05-2013, 09:35 PM)Andy annear Wrote: shes been serviced regularly but not for about 18 months now i think, however she only has 40k miles so shouldnt run rough or struggle to start surely??
should be serviced about every 6 months really mate so you're well overdue . . .first port of call . .Smile
Sounds normal to me lol
[Image: J5hxCcC.jpg]
If your not tuned and not doing mega miles once a year is fine. But most here are tuned so we seem to vary. I service mine every 6000 miles usually before.
(16-05-2013, 10:51 AM)Tom Wrote: If your not tuned and not doing mega miles once a year is fine. But most here are tuned so we seem to vary. I service mine every 6000 miles usually before.
same here, works out about every 6 months more or less . .Smile
haha i love how often this comes up. standerd issue XUD isnt it? iv never owned one that dosnt do this on a coldish morning. even with new plugs, fluids and filters they have always done it
Its good if it sounds clattery as f*ck on a cold morning Smile Means its working right.
ok thanks for information Big Grin but it hasnt been what id call cold at all here? my 106 derv running 60/40 veg/diesel would start alot easier in the morning?
as this is my first 306 diesel wasnt sure to be worried or concerned thats all Big Grin
Cheers!
Mine always does this, new glow plugs didn't slove it so thought f*ck it haha
(16-05-2013, 01:46 PM)Andy annear Wrote: ok thanks for information Big Grin but it hasnt been what id call cold at all here? my 106 derv running 60/40 veg/diesel would start alot easier in the morning?
Cheers!
It isn't going to die any when soon if that's what your worried about
right on ok, Thanks for all opionions Big Grin
mine does this had new glows soon as i rev it a little bit it clears withing seconds i have got the usuel leaky injector seals
Had this EXACT same problem on my DW8, after going through the basics (glow plugs, injector test etc.), found it was valve clearances closed up. Now starts like new.
I think they are meant to be checked every so often, but was never part of the service on mine. Even a peugeot main dealer missed this and failed to fix.
Ok wouldnt personally know where to start with valve clearances myself, so i think after a service and maybe plugs this will be my next port of call Smile
Cheers
(17-05-2013, 01:57 PM)Andy annear Wrote: Ok wouldnt personally know where to start with valve clearances myself, so i think after a service and maybe plugs this will be my next port of call Smile
Cheers
Be wary of that, my mate paid out a fair bit to have the valves re done........... and it didn't stop it from doing it
(17-05-2013, 03:48 PM)puglove Wrote: Be wary of that, my mate paid out a fair bit to have the valves re done........... and it didn't stop it from doing it
They can be checked quite easily. It's actually doing the job that's apparently a bit of a pain. I my case an exhaust valve wasn't closing, so it was a pretty sure bet that was the problem.
Change the glow plugs Andy, will most likely fix 90% of the issues, if you buy a set ill whip them in when im doing the pump, changing to bosch pump will also most likely help alot.
If it was glow plugs wouldn't it run smooth quicker than "a few minutes"? I can start mine without any glow and it will run smooth in a few seconds.
yeh it will, its most likely just retarded timing from worn pump etc, lucas pumps are never the best from cold, lower break pressures, less static timing, etc.
sounds like you have one glow plug that has failed and its running on 3 for a little while
  406 semi ecu XUD9, lumpy/idling issues,advance woes Piggy 3 3,125 28-11-2016, 09:39 PM
Last Post: Seb_Ryan
  Slight starting issue, lumpy idle, etc Dazecoop 6 3,738 05-04-2016, 10:40 AM
Last Post: Iaitoo
Sad Blue Smoke KilianManning 10 7,537 28-09-2015, 11:44 AM
Last Post: KilianManning
