Tyres rubbing on coilover
The inside of my tyres rub on the adjusting nuts on the coilovers. The wheels are td 1.2s and have 205 45 16 tyres. Didn't expect this to happen as the wheels are supposed to be direct 306 fitment.
I suppose the only way around this is to go back to shocks and springs?
[Image: 20120704_212316.jpg]
195's would help... 205's are a bit big. 5mm spacers may give you the clearance you need.
I had the same issue with my PR3's, I removed the helper springs. Before I get slated, because I did it for clearance and not for maximum lows, I wound them back up to make up for the helpers and therefore it's really no different. They only unseat at full droop when jacked up, it'd never happen on the road.
Yea smaller tyres, but might want to check the ET of the alloys.
Yeah I was thinking about removing helpers, might have to do that as I've only just bought some new 205 tyres! Can't use spacers though they are very close to the outer arch as it is.
(13-05-2013, 10:28 PM)Ben Wrote: Yeah I was thinking about removing helpers, might have to do that as I've only just bought some new 205 tyres! Can't use spacers though they are very close to the outer arch as it is.
Have the tires outside the arch. Its a common trend with VAGs in particular.
Otherwise, 195/45/15s ftw Smile
I think you mean wheel ^^
If 5mm would clear it (that's what I needed when I fitted my LM's on the Audi, they were correct offset too, just wider...) then that would be an easier option... It'll only need a slight roll then, not a pull or anything. A few members have an arch roller, the arches on these are like tin foil so it only takes 5 minutes Smile
I should point out I'm already running 20mm spacers, that's why I removed the helpers.
They maybe 306 fittment but nade to be fittment for a standerd car.
try a 3 or 5 mm spacer and just have the return the lip on the arch rolled up . minimal work , clears your brakes, and makes the wheels look better in the arch.
maybe try winding the coilover up a little bit to clear the trye or youll have ot go for 3 or 5mm spacers as said.
I think I'll try some 3mm spacers. Strange thing is there is a gap when the cars on the floor, wouldn't have thought the tyre would move like that when driving but I guess it must move more than I thought.
every car that weve fitted coils (pugs) needed 3-6mm spacers to clear coils. even a 206 gti needed them
[Image: sig-1.jpg]
SOLD
I needed 3mm on the donkey for the sp wheels to clear the coilys.
Mine cleared ta's fine & it was LOW. Bigcheez will clarify
That's on 15's though and the TDs are probably wider...
Yeah true, was mainly referring to Diggers reply but I suppose even that was quite a wide statement as he didn't state wheel size
Ah, didn't see that! It is quite a common problem, due to the lock rings obviously being in a different loacation to normal struts. If I were running 'clones I don't think I'd have an issue
I've got my arch roller ben if you need it mate! We can sort something out Wink
Silver Five Door D-Tuurbo'! More Doors More Whores y0! Wink
  Wishbone rubbing on droplink? Matt 24 13,107 16-06-2015, 06:33 AM
Last Post: ginge191
  rear wheels rubbing gary.jennings050580 7 3,984 18-01-2015, 08:57 AM
Last Post: cully
  Coilover protection lolsteve 6 3,766 09-01-2015, 10:22 PM
Last Post: lolsteve
