Help, broke down!
Help, broke down!
#91
Ah, that says 'component disconnected', would explain the high resisitance...did you leave it plugged in when you tested between the pins on the ECU plug?
Yeh I left it plugged in as surely if I disconnect it then it wont be able to measure the resistance? I assumed it ment the ecu plug disconnected? I tryed the same thing with the fpr and I got nothing when disconnected then I got the correct reading when I plugged it in?
Edit
Just checked by doing the ohms test on the fpr and with it disconnected I didnt get anything but when I plug it in I get the correct resistance. It must mean the ecu plug or wherever your taking the reading from.
Oh, yeah you're right, I wasn't thinking, of course you can't read it with the sensor unplugged lol. lol
Next step would be to test the sensor itself, that will check if the short is in the sensor, or the wiring.
Thought it was me going mad lol
Yep will have to do that tomorrow tho not. Going to have a look on autodata and see if the sensor goes thorough any sort of fuse or anything or straight to the ecu.
Looks like it goes straight to the ecu. so surely its the sensor, as the wiring should measure 0ohms if there ok but I am measuring less ohms than I should. Am I right in thinking?
Yeah it'll go straight to the ECU, I'd go with the sensor shorting out and being at fault then! You're clearly better at this electriconic thought process than I am lol.
(13-05-2013, 07:28 PM)Toms306 Wrote: Yeah it'll go straight to the ECU, I'd go with the sensor shorting out and being at fault then! You're clearly better at this electriconic thought process than I am lol.
I dont know lol maybe with my dad being a electrician I have learned a thing or 2.
This is a quick video of what the sensor measures
http://static.photobucket.com/player.swf...205738.mp4
Do these videos work for anyone else? Beginning to think it's my computer...
You might want to check the wires for continuity before replacing the sensor, just to make sure. But otherwise that definitely sounds like it's your problem, hope it sorts it for you.
No the vids never work here either lol....
Don't know about the vids is strange.
Yeh going to check the wires and if there ok will get a sensor. Thanks lads will let you know.
Just wondering why the code didn't come back?
Is a bit odd the code didnt come back, thats why I reckon it might be a wiring fault rather than the sensor itself, thats just me speculating though.
Yeh I know what your saying but I would of thought if it was I wiring fault then the resistance would be higher not lower?
Yeah, that'd make sense wouldn't it... Rolleyes
Maybe thats our problem, we're trying to apply logic to french electrics lol.
Have you changed the sensor yet then? Tongue
Well what a bloody pain.
Unplugged the connecter, tested the sensor, reads bang in the middle of what it should. Tested the wiring and didnt get any connectivity so obviously nakerd wires. Changed the wiring, connected all back up and now reads the correct resistance at the ecu plug. But...... wont start Angry no idea what to do now...???
One thing, im 80% sure that I got the right wire to the right pin on the ecu from looking on autodata but its not very clear as it doesn't say witch is the voltage and which is the return to the ecu. Didn't want to swap them as it could possibly nakker something?
Ah man, shame that didn't fix it! :/
Can anyone make anything of this? Which is supposed to me the voltage?
Swapped the wires over and still doesnt fire Huh
Hmmm, swap them back and get the code reader on there again I guess, running out of options now... Confused
Have done mate. Going to get someone out later he only charges £40 and I know he is a decent guy so after see what he says.
Sounds like a good option tbh mate, let us know how you get on.
(15-05-2013, 11:42 AM)Poodle Wrote: let us know how you get on.
This! So annoying when people fix things and don't report back lol. lol
Well not fixed yet mate. Someone been and read the codes and the only one he got was p0340 which he says is camshaft/crankshaft sensor synchronization. Although when I look it up it only says the camshaft sensor? Would the camshaft sensor stop it from starting tho?
It started on easy start anyway so its not slipped a tooth.
Wasnt 100% happy really with what he said as I have double checked the ohms of the crank sensor and all is fine and the cam sensor sort of checks out. Although not 100% how to check it.
The cam sensor could stop it, yeah. Again, you could find out it's wiring.
Have you tried again after clearing the code?
Yeh I have. Checked the wiring and thats fine.not sure how to test the cam sensor its self tho as it doesnt say in autodata.
Ah bugger, don't know on that one i'm afraid mate.
Have you tried running her up on brake cleaner or easy start?
Yeh mate it started on easy start, think I said back s couple posts ago.
drag it down the road and bump her at 30 in 3rd, get some more cranking speed.
It won't stay running tho will it? Wont be able to get it back up the road lol
Sorry missed that lol.
It may get her running, worth a try. Got to be someone around who can tow you back up the hill?
If it doesn't start like that, just leave it there....its not like anyone can nick it. Tongue
But seriously, this is why I hate electronic faults, can be such a pain to trace! If I was you, I'd go to the scrappy and get some spare sensors to swap in and out. I binned all the ones from my HDi last week, I'd have posted you them if I still had them. :/
