07-05-2013, 07:39 PM
Separated the door loom today on my td and cant seem to pull it out the car, nor can I see where it goes in behind the fuses. What am I missing please?
2000 2.0 HDi Estate
door loom repair ... what am I missing?
2000 2.0 HDi Estate
07-05-2013, 08:29 PM
It doesn't pull out far...but you just need to pop the grommet out of the chassis door pillar.
07-05-2013, 08:32 PM
there is another grommet behind the door pillar too. not sure how much give there will be but it isnt alot
Venetian XUD ph2 heaven
Ph3 perv cab heaven Black ph1 XUD died Moonstone hdi stage 2
07-05-2013, 11:41 PM
where is the wire breaks likely to be? further inside the car?
2000 2.0 HDi Estate
07-05-2013, 11:46 PM
Breaks are usually near the end with the plug on I find.
08-05-2013, 07:53 AM
close to the plug where it moves most in the rubber grommet tube
08-05-2013, 02:05 PM
It's a bit of a prick to get out, I had trouble too when I stripped the car as you can't see too well behind there.
Door Loom Swapped - Central Locking Fault! | partybish | 8 | 3,049 |
29-09-2017, 08:58 PM Last Post: paulgtt |
drivers door loom wires | pug306driver | 3 | 1,517 |
27-11-2016, 06:29 PM Last Post: BiG K |
Kit Repair door | AmedeoRS | 3 | 1,299 |
07-07-2016, 04:39 PM Last Post: AmedeoRS |
