door loom repair ... what am I missing?
Separated the door loom today on my td and cant seem to pull it out the car, nor can I see where it goes in behind the fuses. What am I missing please?
2000 2.0 HDi Estate
It doesn't pull out far...but you just need to pop the grommet out of the chassis door pillar.
there is another grommet behind the door pillar too. not sure how much give there will be but it isnt alot
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
where is the wire breaks likely to be? further inside the car?
2000 2.0 HDi Estate
Breaks are usually near the end with the plug on I find.
close to the plug where it moves most in the rubber grommet tube
It's a bit of a prick to get out, I had trouble too when I stripped the car as you can't see too well behind there.
Wink Door Loom Swapped - Central Locking Fault! partybish 8 6,868 29-09-2017, 08:58 PM
Last Post: paulgtt
  drivers door loom wires pug306driver 3 3,506 27-11-2016, 06:29 PM
Last Post: BiG K
  Kit Repair door AmedeoRS 3 3,082 07-07-2016, 04:39 PM
Last Post: AmedeoRS
Users browsing this thread:
