Hdi cuts out pump problems
Hi there I've found out y my Hdi wouldn't start a few days ago it was the lp pump in tank so found out a new one fitted in and with a few turns of the key away it went and drive around for a few hours and it cut out again and there is no life at the pump again wat would cause this or can someone point me down the wright path or ill be putting pumps in like there goin out of fashion thanks
Youvalready have a thread on this, have you read the guide as suggested?
Yea I've read the guide and done wat it has said and it's all boiled down to there's no power getting to the pump
Have you tried the emergency fuel cut off switch? (little red one in the engine bay behind the ecu)
Brown relay by the ecu?
You'll know there's only a couple of things that it can be then, as above - brown relay or wiring.
Yea I checked the red cut off that ok ill check the relay next as being studding a wiring diagram of the car and testing the car fuse box and I'm not getting power to the fuse for the pump and by the diagram the relay is next so try that and go from there thanks
  HDi Cuts Out RPug 3 4,762 01-10-2019, 01:49 PM
Last Post: WandaGray
  Cuts out at 2000rpm Dicky 3 3,468 23-10-2014, 09:48 PM
Last Post: Dicky
  Cuts out when driving Frosty 19 10,169 27-12-2013, 10:07 AM
