35mm socket for hub nut- where to buy?
I'm trying to buy a 35mm socket for undoing my hub nut but can't find anywhere that sells them. Tried Halfords and local motor factors but nowhere stocks them.
Anyone suggest anywhere?
2000 2.0 HDi Estate
bought mine from ebay Wink
Need it tomoz tho.
2000 2.0 HDi Estate
You may struggle to get one on a bank holiday weekend tbh, usually have to go to a tool specialist.
Check www.machinemart.co.uk/
Unsure if one local to you
I got mine from ECP.
as much as it pains me to say it but Halfrauds will be your best bet!
A 36 will fit in an emergency
or a 34 and a hammer!
36 is the way forward
And halfords sell them!!
36 is fine, it'd have to be stupidly stupidly tight to be an issue.
(05-05-2013, 10:15 AM)no2lurch Wrote: Need it tomoz tho.
Alright mate if u still after one I have one you can use and also live in cannock
(05-05-2013, 08:07 PM)Jonny81191 Wrote: 36 is fine, it'd have to be stupidly stupidly tight to be an issue.
what . . . .like they usually are? . . .fcuk me i lifted the car off the floor trying to undo them on mine! i'd get the right size to be honest . .Big Grin
undone mine easy only used 3 fingers to hold the air gun Big Grin
36 6 sided you'll be OK...
(07-05-2013, 08:56 AM)Ruan Wrote: 36 6 sided you'll be OK...
^^This
I've only ever had a 36mm one I got from a local motorfactors and it's been fine on every car we used it on.
Meh, did mine with one hand on a 2ft breaker bar.
well yours was easy then, i ended up jamming the breaker bar against the floor and putting the car in 3rd gear to try and break it . . .still didn't work, had to get a bloke the size of Frankenstein to crack it off for us and i'm not small . .lol
Shocked 30/35mm lowering springs Philhdi 1 2,177 23-06-2013, 09:44 AM
Last Post: rocker8742
