Tuning a straight diesel (nad)??
Can much be done to a nad 306, just to make it a bit more bearable, so slooow!!
[Image: DSC_0054.jpg]
Add lightness
Add? Lightness?
more fuel, more air, as much weight reduction as possible
govmod it, and it'll be 50x better, as long as you're not bothered about sitting at 5.5k all the time
Bosche pump in it, but it look different to the turbo one, not sure where the max fuel screw is!
It looks different to a turbo one cause it has no boost compensater on it, the max fuel screw is at the back of the pump on top, you'll see it if you have a look at, like a bit of threaded bar sticking out with a nut on the inner end of it.
So basically to tune it just turn the max fuel screw? anything else that should be done?
Port and polish the head? Works good on petrol NAs so should also benefit NADs?
Dont know how much a full straight through exhaust would benefit, could search about that?
Look after it, always noticed an improvement after a service!
Watch this:
http://www.youtube.com/watch?v=e5lHdZ8gF6E
(06-05-2013, 01:00 PM)Lolben91 Wrote: Port and polish the head? Works good on petrol NAs so should also benefit NADs?
Watch this:
hahahahah so funny Big Grin time to get the angle grinder out Big Grin
  1.9 Straight diesel max fuel? NaughtonGAA 0 2,112 11-03-2016, 07:28 PM
Last Post: NaughtonGAA
  straight diesel 405 conversion to dturbo Dturbobooost 2 2,779 22-03-2015, 09:22 PM
Last Post: Dturbobooost
  XUD9TE into straight diesel PH3? AdamInNi 20 10,337 25-11-2014, 10:30 AM
Last Post: Ruan
