H7 bulb into H4 wiring
Morette using H4 bulbs I am wanting to wire them into a crystal loom. Now my question is the H4 has 3 wires 1 earth1 dipped and1 high where crystals use only 2 wires. If it possible to do this or are phase 2 looms going to be needed?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Worked it out red is high beams and yellow is dipped. But will I be able to run both outer and inner dipped on the same connection without a relay like the original crystal lights do. It works in trial but what about long term
Blaze 1.6 Dead
If you do it the other way when you go from phase 2 (h4) to phase 3 (h7) should think it'll be ok to wire it up like that tbh
The wiring on the phase 3 lights is fairly thin however whats the max it will take i dont want it shorting or melting when its fitted and on for some time. I can plug it in and leave on for awhile and try it i guess
Like this with no relays [Image: 215238_10152773218310392_2114328030_n_zps8cf1498d.jpg]
Blaze 1.6 Dead
  Fog lights, new bulb ROBCAT 0 2,514 14-06-2018, 09:11 PM
Last Post: ROBCAT
  Ph1 replacing dual bulb headlight assembly with a single bulb H4 one The Coolest 9 5,281 13-11-2015, 04:48 PM
Last Post: The Coolest
  Odd Bulb Issue... Toms306 20 9,815 04-10-2014, 02:18 PM
Last Post: Connor
