electric windows not working.
Just driving home after buying my newly acquired ph2 lx dt and the electric windows don't work. Neither work off drivers switch and passenger window doesn't work off passenger switch.
Any suggestions as to what it night be please?
door loom will have a break in the wire. mine had 3 broke so changed the loom and its fine. do the switches light up?
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Will the drivers door loom affect the passenger switch and vice versa? I'll go check if they light up
yes depending on which wire is broken
on my ph3 the pasanger window and both door mirrors stopped working
No levy mirrors here!
less wires to repair then Wink
http://306oc.co.uk/forum/thread-11512-po...#pid228104
Are the broken wires usually easy to see? Could I put a bridging wire in to rejoin them?
all depends what plug you have some plugs are sealed and if the wire is broken close to the sealed plug it could be difficult to get a connection for your bridging wire
but yes bridging is how most do the repairs
And they are easy to spot?
Just checked to see if the switches light up... the passenger one does when ignition is turned on
easy to spot!
yes if they are fully broken once the grommet is peeled back
Do not a door off job necessarily?
makes acsses a lot easyer and door off is only a 5 min job as the door loom is plugged
  off side Electric window and door not working bluebenz1 1 3,399 01-05-2018, 10:07 AM
Last Post: pug306driver
  electric windows sb194114 5 4,085 07-02-2015, 11:14 AM
  Rear Electric windows LewisG 5 3,882 29-03-2014, 08:07 PM
Last Post: LewisG
