running without a thermostat ??
is it bad to to run without a thermostat what are the pros and cons ???
Pro's: it'll keep the engine really really cool so it will rarely overheat
Cons: The oil won't go up to it's proper temperature which means thicker crap moving round the engine causing potential issues.
Black mask Service
also lower efficiency...so lower power and mpgs
plus the cabin heaters will be unlikely to get properly warm
Before we start if your stat isn't working properly replace it. A New one for an XU10 direct from pug retails at £18.04 so not even expensive to replace especially with a discount or a pattern part. Easy job to replace too, just a few bolts and some coolant.
Pros -
Erm, none if your stat is working properly.
Cons -
Never get hot heaters
Reduced power
Reduced mpg
Higher emissiions
Oil temp will never get hot so wont burn off its contaminants
Oil pump has to work harder to pump thick cold oil
Less effective engine lubrication so more chance of premature engine wear
You'll never get it to seal without a thermostat.
The thermostat provides the seal that seals up the cover that the top rad pipe clamps to.
  Correct type of thermostat? carlukepeugeot 1 2,502 02-09-2017, 06:13 PM
Last Post: bashbarnard
  thermostat opening temps...lower temp' stats? Piggy 25 14,529 25-01-2015, 05:10 PM
Last Post: Piggy
Question Leaky thermostat - which one to replace? akiller 6 4,628 30-11-2014, 11:55 AM
Last Post: akiller
