04-02-2012, 08:59 AM
job for after dinner aswell as checking for a duff glowplug or two
whats in the parcel
04-02-2012, 09:00 AM
No you want to push it down the windscreen to remove it. If you hit it upwards, youll just break your windscreen!
Oh and there easy to fit. Was first mod I did to mine. Depending on what model it came off, it may have more than 3 wires
04-02-2012, 09:01 AM
mark_airey Wrote:Toms306 Wrote:Yeah the whole thing just slides..........but the glue on the block isnt all that good and often pulls off with the mirror! In my heavy handed experience anyway! I was fine with original screens........but the 1.4 had a new screen and the block came off, then the 1.8 did the same with an autoglass window!
04-02-2012, 09:15 AM
NiallHarper Wrote:No you want to push it down the windscreen to remove it. If you hit it upwards, youll just break your windscreen! really..........you maybe want to look at that again because i'm certain they don't.........
04-02-2012, 09:59 AM
Im pretty sure marks right.....look where the auto wiper sensor wires are....you have to slide up and over them....
04-02-2012, 10:05 AM
Mine went down. I remember because I remember thinking how odd that is seeing as it would probably fall down being French!
Toms306 Wrote:Im pretty sure marks right.....look where the auto wiper sensor wires are....you have to slide up and over them.... That and eventually with the vibration of the car it would work its self loose and end up on your dash if it slid down to remove it NiallHarper Wrote:Mine went down. I remember because I remember thinking how odd that is seeing as it would probably fall down being French! Fair enough then, yours must be the only one in the world then, I shall take some pics if you don't believe me......
04-02-2012, 10:08 AM
mark_airey Wrote:Toms306 Wrote:Im pretty sure marks right.....look where the auto wiper sensor wires are....you have to slide up and over them.... Nah I believe you. I know how messed up peugeots are lol I also know my mates XS does the same. What ph is your mark? It might be different if you don't have the rain sensor
04-02-2012, 10:17 AM
Mine went down. Remember doing it, thought it would slide up, woulnt slide, pulled abit harder, smash whole windscreen cracks, turns out it does slide down lol
04-02-2012, 10:21 AM
They slide down to come oFf.
Best way to mout it is using tho original mount with a hole drilled through it.
04-02-2012, 10:22 AM
NiallHarper Wrote:Nah I believe you. I know how messed up peugeots are lol this is true, I know that the ph1 & ph2 306, the 307 and the 205 are all the same as I have one of each of the above at home in one state or another.............
04-02-2012, 10:26 AM
Haha nice.
Getting the mirror onto the original mount is a PITA. Luckily mine came from a 406 so the mount was exactly the same so all I had to do was wire it in, slide the old one off and slide the new one on. 5 minute job for probably the best mod I've done! Will warn you now though, the sun visors won't go all the way around anymore
04-02-2012, 10:29 AM
NiallHarper Wrote:Haha nice. mines a 307 one and is also exactly the same mount as mine
04-02-2012, 10:30 AM
I've a 307 one too, but on the stanadard 306 mount.
The 406 ones are just too long to go between the sun visors.
04-02-2012, 10:33 AM
I have a feeling that this is a rain sensor dependant issue, if you have one the mirror removal is down and if you don't then removal is up, just found this too which may be of interest to someone
http://www.306gti6.com/forum/showthread.php?id=102930
04-02-2012, 10:58 AM
Hmm...think I was sliding mine the wrong way then haha!
Anyone had problems with parcel monkey before? | Matt | 18 | 1,973 |
17-09-2015, 12:40 PM Last Post: Matt |
