crankshaft pulley
crankshaft pulley
Hi
I know using the 307 crankshaft pulley is ment to be better as it is a solid one but
Are all the 307 ones solid as when looking on ecp ect they have all different ones, I have found on gsf which looks like the one I need. but looking at the size it is 158 where as the one from the 306 is 162 so would I just get a slightly shorter belt.
If possible could someone give me the part number for the correct one on ecp or carpartsforless.
Thanks for any help.
Im pretty sure you want the one for the 307 2.0 hdi
Yeah I know it the one for the 307 2.0 hdi but there is a few that you can get,
The one that I found on a link on another topic that people said to get is 148 width
But the original one for 306 is 152 so is it worth getting that then get a slightly shorter belt?
I cant say i got my solid pulley from lynx performance. £100.
The tensioners should be more than capable of taking up the slack.
Ok then, thanks for the help. Ill order one and see if not I found a slightly shorter belt now.
  Crankshaft Pulley JTaylor2005 5 1,450 21-04-2018, 06:44 PM
Last Post: Frosty
  Crankshaft Pulley - removing bolt? CaptainHair 19 3,443 10-12-2016, 05:50 PM
Last Post: CaptainHair
  WARNING! Crankshaft pulley issues highwayman306 26 10,803 10-04-2015, 06:34 PM
Last Post: highwayman306
