What clutch cable could i use?
I have a 205 with a 306 d turbo engine and box fitted
Ive fitted the small arm from the 205 box,but i dont know what cable to use
the 205 box was pull and the 306 is push,ive put an old 306 cable in but i had the shim it by about 4 inchs at back of the clutch, it works but is there any other alternative
I'm running a 309 with a 306 td gearbox. I'm using the original 309 1.3 clutch cable with no problems if its any help
(14-04-2013, 09:31 PM)Sambarker Wrote: I'm running a 309 with a 306 td gearbox. I'm using the original 309 1.3 clutch cable with no problems if its any help
Did you need to make any modifications to the clutch cable??
No...
  New clutch cable needed jcsh 3 4,612 11-02-2021, 05:01 PM
Last Post: ekjdm14
  Citroen ZX 1.9 TD Clutch Cable drew 0 2,663 17-05-2019, 12:58 PM
Last Post: drew
  clutch cable routing carlukepeugeot 4 5,341 29-10-2016, 08:24 PM
Last Post: carlukepeugeot
