Air Filter Critique
Air Filter Critique
What do we think about this?
http://www.ebay.co.uk/itm/BLUE-LARGE-PER...53f35bad73
[Image: %24T2eC16hHJGoE9nuQhobbBP5DoVZ,o!~~60_12.JPG]
Obviously its fairly big which is good but its a budget / non branded.
What do we think? Good enough for T25, TD04, GT20's etc? Smile
Yarp. IMO anything that gets through it will be chewed by the turbo anyway.
Defilter ftw, noone wants their turbos to last a while do they?
What size is the neck to go on the intake pipe
S2 HDi >click<
154bhp
280lbs/ft
3" / 76mm.
De-filter isn't for the long run!
Should be fine.. Mines 101mm bit overkill for the maf and GT15 id think
S2 HDi >click<
154bhp
280lbs/ft
(08-04-2013, 05:42 PM)Arron Wrote: Should be fine.. Mines 101mm bit overkill for the maf and GT15 id think
I'm struggling to find anything bigger than 3" outlet.
Look on manufacturers websites, places like RamAir you can spec your own throat sizes etc.
will suck in small children but will be fine Wink
I use a ramair universal foam filter, with 70mm neck. I have 70mm pipe all the way to the turbo which I then have a reducer down to 56mm.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
  3" Custom Downpipe - what did you buy, advice and critique required! silverzx 48 27,091 09-11-2013, 10:53 AM
Last Post: silverzx
