06-04-2013, 03:08 PM
Trying to change my front ns hub here but stuck on getting the ball joint out. any tips?
ball joint removal
06-04-2013, 03:27 PM
At the back if where it goes thru is a split, drive a wedge into that and open up the hub slightly
06-04-2013, 07:02 PM
Take it off the strut first as well, gives a lot more movement then you can turn it backwards so its easier to open up the slit at the back.
06-04-2013, 07:44 PM
Take the pinch bolt out, leave strut connected and batter the wishbone with the sledge... soon gets it out!
06-04-2013, 07:53 PM
But it doesn't....the wishbone pushes back up and fights against you unless the bushes are f*cked....
06-04-2013, 08:19 PM
A yes you are correct Tom, I batter it till it pops down the first bit, then a crowbar to pop it fully!
06-04-2013, 08:39 PM
That's fair enough, but you've gotta be pretty strong.to pop that last bit. Which I'm not lol, do I find it easier the way above. But whatever works for you is good.
06-04-2013, 08:50 PM
Give it a spray of wd40 too
Click to see how smokey is doing
----> Project Smokey
06-04-2013, 10:00 PM
a big lever bar and hammer are your best friends for this job
'09 Mercedes E320cdi wagon '99 306 gti6
06-04-2013, 11:36 PM
I normally just smash the granny out the wishbone with the club hammer until it comes down.
07-04-2013, 08:18 AM
I put a big bar over the bottom arm and under the sub frame and just jump on it! Just mind the drive shaft doesn't pull out the gearbox
| Ball joint/ Hub to strut pinch bolts | Uberderv | 7 | 5,523 |
04-01-2018, 11:40 AM Last Post: Mighty306 |
| fitting a front suspension ball joint | impotentials | 3 | 3,826 |
29-10-2016, 05:46 PM Last Post: Poodle |
| Bottom ball joint sizes | Xsikid | 4 | 3,678 |
04-05-2016, 05:45 AM Last Post: Paul_13 |
