GTI6 anti roll bars
Going to be lowering my car soon (d turbo), wondering is it worth me getting gti6 anti roll bars front and back?
Are they just a straight fit? Would I need to modify any thing to fit them?
What improvment would I expect? Less body roll?
Any thing else I should no?
just grab a gti rear beam...as you want gti brakes anyway...get one with the calipers and its win win...
front gti arb is a big improvement imo
bit of arseache to get off and on...basically undo the pas rack, and drop the subframe by an inch or so to get it out and new one in
PS direct replacement but you need the ARB with bushes or just replace with new and they bolt on your normal droplinks
Is it really that much work to take the roll bar off? Thought it was only a couple of bolts for the brackets and un do the anti roll bar links?
If I was to get a gti anti roll bar for back would it just go straight in my d turbo axle or are they different lenths?
Iv done this on my DT well worth it, a GTI rear ARB is a dead easy mod compared to changing the beam is litraly 5mins
front ARB again fairly easy IMO , dont HAVE to touch the PAS just drop the sub fram by an inch, release the drop link and clamps above the P bush's then wiggle it out the back of the sub frame, reverse for re fitting , simples
Sounds easy enough,,have to see if I can find some gti anti roll bars now
I managed to change mine without touching the PAS or the subframe just wiggled it out the side
[Image: 20120704_212316.jpg]
tom on here is breaking a hdi estate, think theyre simlar?
rear beam would be, if not having thinker torsion bars
Got a gti front here for £20 with bushes?
[Image: sig.jpg]
(01-04-2013, 09:30 PM)sweeney1987 Wrote: tom on here is breaking a hdi estate, think theyre simlar?
I was thinking this is the anti roll bar the same thickness but not meny people wana brake up an axle unless its fooked any way
(01-04-2013, 09:38 PM)Chris Wrote: Got a gti front here for £20 with bushes?
How much posted? Pm me
just put in whole axle, easier plus disc breaks Big Grin
PM'd Smile
[Image: sig.jpg]
(01-04-2013, 10:06 PM)sweeney1987 Wrote: just put in whole axle, easier plus disc breaks Big Grin
Deffo Not easier than just changing the ARB's over.
But IIRC ph3 estate ARB's are GTI spec
Does anyone know the definitive answer to what the colour bands mean....not 'I think its....' but does anyone know for definite which are which? Smile
2x silver bands - GTi6 - 20mm
2x green bands - VTS - 21mm
colour bands?!
(02-04-2013, 08:08 PM)Niall Wrote: 2x silver bands - GTi6 - 20mm
The other day you said you weren't sure which is why I asked lol. lol
If thats true though, there are two silver bands on the bars from my W plate estate..... I thought it was only the much newer ones ('51+) that had them.
nah i found a pic of my gti ones today and they are silver bands so has to be that way round
Ah ok, well that proves it then.... The ph3 estates do have GTi TB's. Smile
Not sure about the ARB's though, I assume they're the same as well then?
An the arb is tiny even on the cars with 21mm bars.
It likely to be y plate on for the 21mm bars and the 22mm front arb.
Also 20mm bars are red and 21mm are black out the factory.
[Image: sig.jpg]
  Rear anti roll bar Tidoh2016 3 3,359 02-03-2018, 12:18 PM
Last Post: Tidoh2016
  GTI6 beam fitted, front end now has more roll MY95 78 37,437 08-05-2016, 09:24 AM
Last Post: MY95
  Front Anti Roll bar and bush few questions titch 17 9,516 18-05-2015, 11:06 AM
Last Post: titch
