Shock locating tab
Shock locating tab
On pretty much every 306 shock i have seen, there has been a T shaped locating tab on the rear to locate the shock in the hub. On the standard shock and my B4s and the cheap chinese coil overs, they seat in the hub with probably 3-5mm of space left in the bottom of the hub however my B8s have about 10-15mm gap at the bottom yet the locating tabs are sitting home where they should be. I was considering cutting the sides off the T so its just like a I so i can drop it further into the hub which should be more secure and also drop the car a little bit more. Anyone see any reason why i cant do this?
Ive always had a nobbly bit on every shock Ive changed, when it stopped moving, it was home properly Tongue
See the 'nobbly' bit is home fully sitting right on top of the hub so wont down any more but the base of the shock is still about 10mm higher than the bottom of the collar that clamps round the shock.
Problem?
double check they have sent you the right ones?!
They are the right ones
Can't see any problem with doing that. If you cut them and it does turn out to destroy your car it wouldn't be hard to weld a tab back on
[Image: 20120704_212316.jpg]
  Rear shock bushes Tidoh2016 2 2,782 12-05-2018, 09:38 AM
Last Post: pug306driver
  Whats the difference with these shock kits? JTaylor2005 8 4,875 04-04-2016, 01:59 PM
Last Post: JTaylor2005
  rear shock swap 306pc 2 2,419 18-06-2015, 10:57 PM
Last Post: 306pc
