bosh pump question
hello guys right i have a question. every bosh pump ive seen are the same but the rev lever above the spring is a thread and bolt and every pump ive seen the thread is not sticking up as much as mine there just above the nut. been told it could have been played with but not to sure.
[Image: IMG00674-20110915-1638.jpg]
cheers guys
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Yeah that looks like about 1cm more thread than usual. The thread usually only come out like 1mm above the nut. Aslong as it runs fine though then I wouldnt worry about it.
ye it runs fine just wasnt sure if its got different internals
Ph3 perv cab heaven
Black ph1 XUD died
Looks like an ex xantia / 406 pump or something, the longer shaft is because it used to have a throttle potentiomter on top if it, which goes over the extra long shaft with a second nut Smile
As said, no problem at all / wont effect anything Smile
ok cheers guys
Ph3 perv cab heaven
Black ph1 XUD died
lso forgot to mension how hard is it to change the seals in the pump. i removed the lid of the top and the black circle rubber and there was oil underneath it
Ph3 perv cab heaven
Black ph1 XUD died
Can I just say, cover up the bare solder joint... At least just wrap some lx tape round it!
That connection isn't fused, if you short it, the ENTIRE engine loom WILL melt... I'm sure there's someone on this forum who can agree with me on that one, I've seen it a few times.
i have put some conectors on it and tape mate this is a pic from when i got it fitted but cheers anyways Smile
Ph3 perv cab heaven
Black ph1 XUD died
karl1989 Wrote:lso forgot to mension how hard is it to change the seals in the pump. i removed the lid of the top and the black circle rubber and there was oil underneath it
Thats the boosted air side of the LDA so its coming from the turbo most likely and its pretty normal for their to be a bit of oil in there mate, don't worry Smile
Team Orange Engine Bay
ok thats something less to worry about cheers matey Smile
Ph3 perv cab heaven
Black ph1 XUD died
karl1989 Wrote:ok thats something less to worry about cheers matey Smile
It is unless there is a lot of oil in there in which case your turbo is buggered and leaking like hell Tongue
Chances are though that is just a build up of oil from over a period of time Smile
well a forum member spun my lda and noticed it but since then i have changed the turbo Smile. the turbine on the old turbo was chewed up
Ph3 perv cab heaven
Black ph1 XUD died
It'll be fine, rag on.........................
  Bosch Pump Question Stuart C 10 7,236 04-10-2016, 06:37 AM
Last Post: Matt-Rallye
  Bosch pump plumbing question 089 4 3,996 11-04-2016, 02:55 PM
Last Post: zx_volcane
  ANOTHER Bosch pump question. 205dtub 7 5,101 02-12-2015, 06:19 PM
Last Post: 205dtub
