Exhaust Manifold Spacers
Does anyone know what size the exhaust mani spacers are? Since changing my manifold gasket, it has started blowing again. I've stripped the intercooler off and I can see at least 1 spacer+nut missing which must be allowing the gases past. And would these ones from a 206 fit if I can't get new ones in the right size?:
http://www.ebay.co.uk/itm/Peugeot-206-1-...35c58f6fee
306 ones are spring loaded ones iirc. They look similar to that but they have like a but with a cap
I used a clothes peg hook :-) same size and done the job until the car died :-)
/pikey
I'm afraid I don't followSad The spacers that I removed from the exhaust mani studs were just a cylindrical piece of metal. I can't see how a spring would fit into them, but I could be wrong. Edit: are you sure you are not getting muddled up with the downpipe bolts/nuts? They have a spring in them to absorb vibrations.
Those might be ok, certainly look similar to the ones I put back in the other day.
Any ones I've seen from a turbo are the same size, unsure about non turbos
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
Okay next question: how many studs are there? I seem to think it was 8 but from this photo I would work out that it is 6:
[Image: P1010009_zps15825206.jpg]
You can see the stud that is missing the spacer there, btw.
There's 3 each side pal 2 at the top one at bottom same the other side 6 altogether
Team Doesn't own a 306
I had this problem but the threads on 3/4 holes in head were stripped so i helicoiled head and put bolts same size as thread on the stud in place you could do that on this one bolt and use 13mm deep socket to nip up with a washer
[Image: J5hxCcC.jpg]
  Exhaust Manifold Pressure gauge install HDIkyle 19 13,691 30-06-2015, 08:51 AM
Last Post: mr_fish
  Exhaust and inlet manifold spacers and studs andyyy 1 2,286 15-03-2015, 01:51 AM
Last Post: zx_volcane
  Exhaust manifold flange anto 15 8,395 04-03-2014, 12:15 PM
Last Post: anto
