01-03-2014, 09:40 AM
Anyone selling an off the shelf manifold flange or is it basically a custom made bit from an engineering firm?
Looking to make up my own log manifold.
Exhaust manifold flange
01-03-2014, 10:56 AM
You could make one from steel plate and a plasma cutter i would of thought. Or somehow make a template and get a company to laser/water jet cut it out for you... Or cut it yourself with a grinder lol
01-03-2014, 11:36 AM
Macclesfield Laser will be able to help you if you send them a drawing/ tracing of what you need: sales@macclesfieldlaser.co.uk
They cut a lot of exhaust flanges for me and the service is good.
01-03-2014, 09:48 PM
By the sounds of it il probably end up doing it with the grinder!
@simonh - what sort of money would they charge for that type of flange?
02-03-2014, 08:35 PM
Get the hacksaw and file out to play?
03-03-2014, 08:55 AM
Stitch drill & get yer file out!
(02-03-2014, 08:35 PM)joe1joe Wrote: Get the hacksaw and file out to play? (03-03-2014, 08:55 AM)Ruan Wrote: Stitch drill & get yer file out! Old skool... thats how i made my adaptor plates for the td04. Seriously time consuming, but then im in no rush so this is probably the cheapest and best solution.
03-03-2014, 11:16 AM
Yeh stitch drilling is the way if you have time. Can make up some complex stuff like that, I found it easier to make a paper/plastic template to get the correct spacing and a punch to start your drills on. I did all my flanges like this and they turned out alright.
03-03-2014, 01:43 PM
(03-03-2014, 11:16 AM)Dave Wrote: Yeh stitch drilling is the way if you have time. Can make up some complex stuff like that, I found it easier to make a paper/plastic template to get the correct spacing and a punch to start your drills on. I did all my flanges like this and they turned out alright. I was going to use a metal gasket as a template. Im really only making one for the craic, ive been reading too much of the merc lads on superturbodiesel and wanted to give it a go.
03-03-2014, 04:28 PM
I'd imagine you'd be around £15 or so plus vat and postage.
03-03-2014, 09:11 PM
03-03-2014, 09:54 PM
Surely you'd be better off with a grinder with a flap disc than a file?
04-03-2014, 08:27 AM
(03-03-2014, 09:54 PM)Tom Wrote: Surely you'd be better off with a grinder with a flap disc than a file? Try getting a grinder into an XUD head port pattern :p
04-03-2014, 09:29 AM
Yeah sure if you can find someone that doesn't have a min order / setup charge - most places will want a min of £75 from you, if they want the job at all.
(03-03-2014, 09:11 PM)anto Wrote:(03-03-2014, 04:28 PM)simonh Wrote: I'd imagine you'd be around £15 or so plus vat and postage.
04-03-2014, 12:15 PM
(04-03-2014, 08:27 AM)Dave Wrote:(03-03-2014, 09:54 PM)Tom Wrote: Surely you'd be better off with a grinder with a flap disc than a file? Agreed. Although i have an air powered die grinder so itl make life a little easier. Il probably just make one, the fun is in the building/ fabricating
| Exhaust Manifold Pressure gauge install | HDIkyle | 19 | 14,211 |
30-06-2015, 08:51 AM Last Post: mr_fish |
| Exhaust and inlet manifold spacers and studs | andyyy | 1 | 2,353 |
15-03-2015, 01:51 AM Last Post: zx_volcane |
| Exhaust manifold design | Uberderv | 72 | 42,027 |
04-01-2014, 11:18 AM Last Post: Rippthrough |
