Droplinks.... buy standard or are there uprated??
Im rebuilding all the front suspension and front components on the DT ready for when i finish the new engine, im just woundering if there are any upgrade to the standard plastic/thin metal drop links as they dont seem to last that long and really pi** me off with the flimsyness of them....
yes.....adjustable rose jointed ones
I don't know if Phillipm on the '6 forum (Rippthrough on here) is still making his, but IIRC they're about £80 a pair? Can be had cheaper 2nd hand, so keep an eye out for them, as they are better than standard ones!!
i bought a set of thick solid adjustable from a lad on here. exactly the same as the ones mentioned above just without the rose joints. £42 on EBAY. search universal adjustable drop links.
these will stop any flex in the link therefor making the ARB more responsive. so yeah a good upgrade at a decent price
But surely you want some give in a droplink otherwise you're just asking for it to snap. Confused
id be suprised if the ARB was able to snap the links iv got!
like this http://www.ebay.co.uk/itm/ADJUSTABLE-DRO...5aeea49598
Thought there was a discussion a little while ago saying solid drop links can transfer the stress to other parts of the car?
[Image: mcetg0.png]
of course it does but so do coilovers, lower profile tyres , solid top mounts, etc. but not enough to couse any serious damagebto anything.
its pretty much the same story with any mod . you just gota weigh up what you want
handling or slightly longer life span on disposible parts
(26-03-2013, 01:06 PM)puglove Wrote: of course it does but so do coilovers, lower profile tyres , solid top mounts, etc. but not enough to couse any serious damagebto anything.
Take all the OEM disposable parts out, problem solved! Big Grin
And seem weld your entire body to cope with the extra stress? Would make for a win handling car!
exactly Ed !!
niall constructive in put only you lanky f*ck wit
<3 you really Tongue
That was constructive. Would be epic!
OC support van as the test pilot?
cheers guys, will get some of them universal ones, cars getting a new front arb aswell so should be ok
(26-03-2013, 02:21 PM)Niall Wrote: That was constructive. Would be epic!
you would see epic issues with glass stress marks on your windscreen etc
into need a full weld in cage territory
its why I think rosejointed stuff is ideal for track but not a daily drive
(26-03-2013, 02:42 PM)Shea Wrote: cheers guys, will get some of them universal ones, cars getting a new front arb aswell so should be ok
dap a gti ARB in there i done it on my DT makes a worth while difference
Yeah looking at gti front and gti rear arbs, uprated p bushes on wishbones, polybushes in the wishbone + arb bushes, cheap set of coilovers for now...
If you want something better than standard without buying adjustable ones Meyle HD are good and cost the same as pug oem ones.
(26-03-2013, 04:39 PM)Dum-Dum Wrote: If you want something better than standard without buying adjustable ones Meyle HD are good and cost the same as pug oem ones.
Where can you buy them from?
http://www.ebay.co.uk/itm/Peugeot-306-Ra...4171396110
My entire suspension system is all metal/metal rose joints and bearings, there's no rubber in it any more, and it rides a lot better than most people's standard cars slapped on cheap coilovers.
when you say its all rose jointed, have you replaced the lower ball joint with rose joints?
(26-03-2013, 08:03 PM)Puggie Wrote: http://www.ebay.co.uk/itm/Peugeot-306-Ra...4171396110
has anyone brought these before?
  Uprated dampers on standard springs? gti6man 5 3,367 28-02-2018, 02:04 AM
Last Post: Rippthrough
  Rose jointed droplinks Hdi and proud of it 18 10,320 23-03-2015, 10:58 PM
Last Post: Kezzieboy
  Gti6 droplinks procta 12 4,502 15-11-2014, 04:21 PM
Last Post: Jiffy
