Manual Boost controller
Turned up fueling.Looking to turn up boost now using a manual boost controller,
Is anyone running one,and which controller is best to use?
I have seen this one but not too sure if its any good:
http://www.ebay.co.uk/itm/MANUAL-TURBO-B...51a6f639c5
Iirc you should use one of the ball bearing type controllers
Most should be fine
You want one of these types mate
http://item.mobileweb.ebay.co.uk/viewite...6443221168
There the best and most reliable ones
Team Doesn't own a 306
that one only goes up to 40 psi =/
Only? What turbo are you running? Lol
http://www.ebay.co.uk/itm/190814511385?s...1497.l2649
This is the one i have, if you want more than 2bar just put a stronger spring in it
It arrived next day delivery. just dont buy one of the gtchris ones, the quality is crap
(26-03-2013, 07:38 PM)4WayDiablo Wrote: Only? What turbo are you running? Lol
K14lol Just drawing people's attention to the fact for extreme tuning purposes lol.
Ball and spring type ftw, one of them popped my, erm, second? GT20. Held a good 35+psi, went off the gauge at that so can't comment on higher lmao
What type of hose would you recommend on using??
5 or 6mm PVC fishtank hose is holding up fine on mine.
(01-04-2013, 08:21 PM)cwspellowe Wrote: 5 or 6mm PVC fishtank hose is holding up fine on mine.
+1 on that. pets at home FTW
  K14 Boost controller ADV_93 7 4,930 27-07-2013, 12:54 PM
Last Post: ADV_93
  Boost controller martyn92 23 14,148 05-07-2013, 05:03 PM
Last Post: Mattcheese31
  manual boost controler ladanivabelgium 14 7,341 18-06-2013, 03:47 AM
Last Post: ladanivabelgium
