Painted Door Vinyl
Painted Door Vinyl
Hello!
Last year the black door vinyl was ripped and peeling on the 1.8 so I took one of them off and replaced it with black gloss vinyl I got off ebay. Did the trick once I had used ethanol to remove all the sticky crap it left behind. Its a farily tedious task though and cutting the right shape is a pain and cutting a straight line for the back of the door never looks good as original.
i know you can get the OEM vinyl precut from peugeot for something like £12.
but what would it be like to paint it?
I presume as long as you mask off the top and bottom properly you would get a crisp line but what would it be like painting on the existing paint? Last thing you really want to be doing is sanding off the OEM paint D:
Just an idea anyway! Thoughts?
My answer to all paint issue, plastidip it.
Leave it off? Looks better
ah yep. thats the spray it rubber paint stuff isnt it? gokod idea and then if it messes up i can peel it off! Big Grin
For the inside of the doors obviously have to mask it off a bit but i could always use a scalpal to make a fine line and then peel off the extra bits.
god idea! thanks mark! Any idea how many cans i need for just doors? 2 would be more thane nough i would have thought!
(24-03-2013, 12:24 AM)Connor Wrote: Leave it off? Looks better
i knew somebody would say this. it doesnt look better on diablo D: It leaves you a massive red gap in the middle of your windows!
Surely you of all people would prefer it to be red...
(24-03-2013, 01:24 AM)Connor Wrote: Surely you of all people would prefer it to be red...
as opposed to green! TMI
One.
Dipyourcar.com on YouTube. Watch a few vids no need to mask anything bar the top line.
Spray, then on the finally coat remove the top masking and it should leave a crisp line need about 4 layers of dip so maybe two cans just to be safe.
Then plastidip uk for the cans.
VHT Vinyl spray!
best there is on the market!
  Vinyl Wrap Removal Toms306 1 879 01-07-2014, 10:53 AM
Last Post: kentiiboii
  Vinyl dye RED gti pugtk 3 1,229 09-12-2013, 07:45 PM
Last Post: John1.4
  painted steel wheels... pugjohn306 8 2,853 13-09-2013, 11:22 AM
Last Post: devils_fuel
