poly lower mount?
Pretty sure my lower engine mount is screwed. Looking at a powerflex one off Ebay. Doesn't say it's specifically for an xud I'm just guessing there all the same
What's fitting like on these too
Thanks
If it says XU then it will fit Smile
Fitting the new one is very easy, but removing the old one is a pain as you have to cut it out unless you have a press and remove driveshaft etc
[Image: 65613_10200761612710317_1548698655_n_zps68c27004.jpg]
CONVOI EXCEPTIONNEL
It will be pretty bad vibration wise in the car mate; I witnessed darrens car at idle with one on, you could actually see the car shale...
I have one still boxed I can let you have for £20 posted.
It was taken out of the box and greased up ready to fit but it never happened as I bought a set of Baker mounts so it was cleaned off and put back in the box.
Hmm mine didnt change when I fitted one, only started getting bad noise when I changed the upper mount
CONVOI EXCEPTIONNEL
Yeah I thought the bottom Mount just took up the forward/backwards movement of the engine. Should be ok thanks for the advice ash240970 you have pm.
Cheers
They arnt that bad tbh ive got the powerflex bottom one and seems fine,;might be a different story when i get uprated top and gearbox though
[Image: J5hxCcC.jpg]
ive got bottom one noticed abit more vibration when i first put it on but got used to it after about 2 hours not bad at all tbh, been in jenks car with the solid mount to be fair was loud is on tick over but soon as you set of wasnt that bad at all tbh soon get used to it.
  Lower engine mount Ricky 8 4,105 27-12-2012, 10:26 PM
Last Post: David
