Lower engine mount
Well i'm ashamed to say when I fitted my engine and came to fitting the lower engine mount bolt, I couldn't be bothered to get the torque wrench out, and just did it up tight, like really tight. NOW the car vibrates like a bugger on idle, what's the torque setting for the mount and could having it done up too tight be causing the roughness on idle?
Many thanks Smile
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Shouldnt do because there is a steel pin through the middle of the rubber anyway which the fork bolts around so you could do that up as tight as you like and it would still be damped by the rubber.
Hmm, need to find this vibration, the old engine didn't do it, and i'm 99% certain the exhaust isn't touching the car anywhere.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
It's because it a new mount, sounds like your old one must have been buggered.
[Image: 704e7db1.jpg]
It should settle down! Have you made sure the down pipe isn't catching the subframe, when mine was it was a horrendous vibration through the car
[Image: SDC10442-1.jpg]
It's the mount from my old engine, so nothing new.
I really need to do an in depth check on the exhaust, needs to be removed and re sealed anyway.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Try getting a new mount?
I will be getting a powerflex or similar soon, but that's not really the solution, it's the same mount as before and as they can't be overtightened there must be something else.
Plus I really don't want to fit a new mount in this weather! Will have to swim to the car soon :/
GT2052s DTurbo
OEM+ HDI Estate
Project thread
I moved my engine forward the other day and now one of the mounts that was fine before now needs changing. Change and just go from there dude.
  Top rubber engine mount Pearcey1995 2 2,426 01-06-2015, 06:46 AM
Last Post: gregpurdie16
  Facelift berlingo d turbo rear engine mount problems Jamieh2013 7 5,221 12-05-2015, 05:01 PM
Last Post: Jonny81191
  Rear engine mount help ADV_93 3 2,750 29-07-2014, 06:03 PM
Last Post: ADV_93
