HELP again....... running like shit,
Right so iv finaly got it running bit it runs like shite. what do i need to do , and please dont say i need to have the cam belt off again Sad
Video coming as soon as its up loaded
Might of shat a con rod now :/
http://www.youtube.com/watch?v=9U6hUWMsa-c
Wow that's dodgy!
Sounds like something is tapping?
White smoke, as I guess you know, can be unburnt fuel, mine used to do it when hunting on veg at cold.
Got the pump retarded? Mine sounded similar, advanced the f*ck out of it and was fine
Fooking turbo oil feed is leaking like f*ck aswell.
What way do i pull the pump to advance?
Lda towards the tmic dude
As said ^^^ give the pump a push, all the way back. That sorted mine
Check the timing again mate mine was like that and it was a tooth out
Team Doesn't own a 306
Timing, fuel filter (check for leaks, air getting in etc), advance/retard the pump.
  Running like shit need help changed everything now with video first post Danny2009 41 18,700 21-11-2012, 09:46 AM
Last Post: Mattcheese31
