sheared wishbone bolt?
This is a reaally dumb question but I went to check over the car today and found one of the p bush bolts wouldn't torque up, it felt like it was sprung so I would try to tighten it but it would just go back the original position again. Same would happen if I tried to loosen it so I decided to leave it be.
[Image: 31yKuQcbHBL._SL500_AA300_.jpg]
It's the one that goes into the rubber so is this anything to worry about?
[Image: sigjpg.jpg]
Serious.
Needs to be bolted in really and it shouldn't be spinning. Should do up nice and tight. Worst case is a new wishbone is about 25 quid
I've got some new p-bushes can post for a tenner if you need.
NiallHarper Wrote:Needs to be bolted in really and it shouldn't be spinning. Should do up nice and tight. Worst case is a new wishbone is about 25 quid
Not really, worst case scenario is it's sheared inside the bush and can't be extracted. Then it's a whole subframe replacement job. Happened to me 6 months ago when investigating a knock, couldn't get the bolt out!
Why would you need to replace subframe for that bolt?!
Just undo the other one and take the wishbone off?
Doh, I was talking about the forward bush
cwspellowe Wrote:Doh, I was talking about the forward bush
Even if it's sheared In the subframe, iirc the front nut isn't actually welded to the subframe. It's held in place by a clip I think so you could just remove the t and put a new one In. Might be getting mixed up with the 106 though lol
Some subframes it's clipped, early ones are slide in square nuts.
Mine's a slide in square nut at the front on a '98.
  Wishbone bolt head sheered off when removing dantheman51838 3 3,038 23-11-2014, 04:59 PM
Last Post: Nath140889
  Wishbone front bush bolt to subframe nut retainer? mattgreene 29 13,284 04-03-2014, 06:44 PM
Last Post: mattgreene
  sheared wheel nut :-( 4WayDiablo 18 9,870 15-04-2012, 09:38 PM
Last Post: 4WayDiablo
