help! now wont start
Right guys I just changed the oil and filter then the fuel filter. Started fine after changing the fuel filter, then I shut it off, went to start again and nothing !
clocks have died. Ignition won't even come on now
fuse? or what else ? need help
[Image: 20gh7o0.jpg]
Check the battery terminals are on tight Smile might have knocked them
Cheers mate will do. All I can think is when I was draining the filter housing I spilled a fair bit of fuel cos my bottle slipped unless its wiring?
Give the battery terminals a bash
Right she fired again after disconnecting the terminals and reconnecting. Think my neg terminal may be a bit dodgey. Would that cause that?
Yup if it's loose, give it a wiggle see if the actual battery terminal moves, if it does new battery time, or keep hitting it when it plays up lol
  HDI wont start whitlam222 31 9,930 19-01-2016, 05:00 PM
Last Post: whitlam222
  HDI wont start jaycc 8 3,931 09-07-2015, 05:11 AM
  car cut out and wont start tuttyboy84 18 5,797 17-02-2015, 09:41 PM
