Computer experts help
Got a Fujitsu Siemans Amilo Pi 2512 laptop that was sent off for the charger port repaired and since we have had it back it will not boot. Was originally on Vista so have try'd to put XP Home edition on but it comes up with a NTLDRL missing. So have try'd a windows 7 disc which i have on my own laptop and PC fine but that also comes up with an error message during the installation.
Anyone got any idea of whats the problem and how to solve it?
Thanks
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
I think you have your boot drive set wrong
you need to go into the BIOS when it gives you the option (usually the delete button) and set it to boot from the CD drive.
Yep do that it gets an error when it gets to the install
Blaze 1.6 Dead
What you do is call the company you sent it to for repairs and tell them to sort their shit out.
It was sent there ages ago some time last year but only just got round to sorting it.
Blaze 1.6 Dead
Ah, bugger haha.
What's the hdd type? May not be compatible with windows 7, I had the opposite problem when i tried to install XP on mine. To make it work i have to go into bios and change the drive type, you never know it might work lol.
I'm not sure tbh it does say something about a drive not been detected I have removed and refitted it also but same messages.
Blaze 1.6 Dead
http://www.youtube.com/watch?v=WyT4AmjvMeI to attempt to fix ntldrl if it's damaged install
Or
What poodle is talking about is the Sata drivers for the hdd, Xp doesn't support AHCI native and has to run in Ide form by default whereas Vista/7 does. So it could be that you're computer is running Ahci and you're trying to boot xp which wants ide
You can make xp run in ahci, if the drivers are there from the computer manufacturer iirc
http://superuser.com/questions/333052/ch...installing
[Image: mcetg0.png]
(26-02-2013, 11:13 PM)Poodle Wrote: Ah, bugger haha.
i had the same thing when i tryed to duel boot a vista laptop with XP
when i want xp i have to go into bios and change
(system config/SATA operation) from AHCI to ATA
  Computer gurus - crashing PC ginge191 8 4,800 24-02-2017, 08:14 AM
Last Post: MisterGTR
  Windows 10 experts help if possible. toseland 4 3,152 10-10-2016, 03:38 PM
Last Post: Ruan
  Arduino Experts. ConorTRG 4 3,227 04-06-2016, 03:30 PM
Last Post: ConorTRG
