23-02-2013, 11:08 PM
hey,
i have a 1.4 r reg 306 and am changing the spark plugs what is the size of the gap needed???
Spark Plug Gap?
hey,
23-02-2013, 11:15 PM
the plugs should come preset gapped...
dont fiddle unless you are modding Wishes for more power...
23-02-2013, 11:39 PM
What? dont change the gap! They are set from the factory! Maybe give them a little sand with sandpaper just to clean the contacts but dont go changing anything!
If you want to be part of the fast and the furious then get these! ![]() Then you can brag about how your spark plugs have four prongs
24-02-2013, 07:37 AM
As said you only need to gap plugs if they're old usually. But its 0.9mm for 1.4s iirc.
24-02-2013, 01:09 PM
A mentioned plugs should already have the correct spacing if purchased new. according to auto data gap is indeed 0.9mm
| Spark plugs | Seid' | 10 | 6,995 |
13-06-2012, 07:19 PM Last Post: puglove |
