k14 out let size??
k14 out let size??
As above any one no what size the out let is on the k14 so I can get an adapter to fit my intercooler pipe work
i would guess 2" mate . .Smile
Need to no for certin so I can get right adapter be nice if it is 2inch cos should have one in shed that will do it but I thought it would be smaller than 2inch
(18-02-2013, 09:09 PM)Chris_90 Wrote: Need to no for certin so I can get right adapter be nice if it is 2inch cos should have one in shed that will do it but I thought it would be smaller than 2inch
just going on the other end of the pipe that joins to intercooler, that's 2" iirc . .which i may not . .lol
K03 is 41mm IIRC, I guess it'll be similar so 50mm sounds about right, it'd probably clamp down ok anyway if you used a good quality clamp.
51mm fits fine with a jubilee.
Bye Bye D-Turbo
  Top mount intercooler bolt size/ timing hole size LewisG306 2 2,722 13-07-2014, 10:44 AM
Last Post: LewisG306
