Brake warning light always on
Okay I think this is related to my instrument cluster fault since it cropped up after I removed and replaced the cluster. The brake warning light is always on except when I push the brake pedal then it goes off. I have checked the plug on the master cylinder reservoir and the handbrake button. Now, I know when you press the brakes and the light comes on it means the pads are low, but the other way around I'm clueless.
mabye you messed summat up putting the cluster back in might be a ball ache but can you take it out and have a look?
[Image: redranger.jpg]
Phase 1 ? Funny as it sounds you may have one of the connectors upside down. This exact thing happened to me.
[Image: Atterz.jpg]
Hi Atterz do you mean the connectors to the instrument cluster? Yeah it is a phase 1 btw.
  Brake light switch parts exploded view pug306driver 11 10,158 13-12-2021, 06:11 PM
Last Post: Mighty306
  Brake light switch pug306driver 10 8,631 14-10-2021, 01:18 PM
Last Post: pug306driver
  Battery warning light/fuse keeps blowing.HELP Clump1298 8 7,073 03-09-2020, 08:21 AM
Last Post: ekjdm14
