Convertible 306 beam fit a estate ?
Anyone know if the rear beam off a convertible 306 will fit a estate ? Found a 51 plate low milage convertible in the scrap yard just wondered if they are any different ?
i believe they are all interchangeable mate . .Smile
Yeeeeeeep
But if your eastate ph2 you will need to swap a few things about. If your estae is ph3 it will be a straight swap
What needs to be swapped if its a phase 2 ??
The estate will probably have bigger torsion bars in it to handle the load weight!
Straight fit mate if yours is drum you just need new handbrake cables as its different with disc axles.
Bye Bye D-Turbo
(18-02-2013, 10:34 PM)Willo Wrote: What needs to be swapped if its a phase 2 ??
Ph3 have a different ABS System that dosnt need a brake load sensor. There for the beam doesnt have a load sensor and slightly different lines
Ph2 has a ABS system. That needs a load sensor that is attached to the beam and runs aload more lines.
Some ph1s / pov spec ph2 have no ABS there for no brake load sensor. But again i think the lines differ from a non load sensor beam because of the ABS.
If you handy with the spanners and problem solving you can easily get around this by swapping the lines and brake load mounts about from beam to beam
So yeah you just need to swap some lines and the beam/shock/ brake load mount < all one mount
Oh right I don't have abs on mine but I have a load sensor or what I think is a load sensor anyway
  Hdi estate rear beam for free WILL1000 3 3,237 01-09-2015, 12:40 PM
Last Post: WILL1000
  Estate Rear Beam On A Phase 1 Dturbo seanyleary 8 6,050 19-07-2014, 01:18 PM
Last Post: Toms306
  GTI beam on estate....a bit low? Andy! 9 4,255 25-11-2013, 03:57 PM
Last Post: anto
