03 xsara estate beam fit 306 estate?
Been offered a rear beam off a 2003 xsara hdi estate any one know if this is a straight swap for my 2001 306 hdi estate or did they change them ie different abs wires brake lines and handbrake cables ? Any info on this would be greatly appreciated
Cheers
The beam itself should be the same, though I can't say for certain about the wiring. I believe it would be, as the looms are the same between the Xsara and 306 if I remember correctly?
Cheers for the reply, would it just be a matter of switching the calipers over if they didnt match up ?
Almost certain should be the same just a straight swap if yours had discs. And being an 03 plate should be in half good condition.
Bye Bye D-Turbo
Yes it's a straight swap, should have 21mm black torsion bars aswell, which is a bonus Smile
[Image: 704e7db1.jpg]
What are the colours and sizes of the torsion bars then ?
All red lol
Gti6 is 20mm
Xsara / late 306 estate 21mm
Everything eles - to small lol
21mm torsion bars are black.
  Estate handling mods Tabbiss 2 3,420 24-10-2019, 04:53 PM
  Help lowering estate camoturd 2 2,435 25-11-2015, 09:04 PM
Last Post: Magenta Sunset
  Hdi estate rear beam for free WILL1000 3 3,043 01-09-2015, 12:40 PM
Last Post: WILL1000
