13-02-2013, 10:40 AM
Hello I've changed some brake pipes on my 306 hdi with abs. So I need to bleed them in this order?
osr, nsr, osf and nsf
thanks
thanks
Bleeding brakes 306 hdi abs
osr, nsr, osf and nsf thanks
13-02-2013, 10:46 AM
The advice I was given was start at the furthest away and end at the closest to the master cylinder so on mine it would be nsr/osr/nsf/osf
13-02-2013, 01:13 PM
(13-02-2013, 10:46 AM)Willo Wrote: The advice I was given was start at the furthest away and end at the closest to the master cylinder so on mine it would be nsr/osr/nsf/osf Correct. I duno if it really makes that much diffenece tbh. Just make sure you dont run out of fluid while bleeding it through
14-02-2013, 01:38 PM
All done now like new now thanks
| Bleeding Brakes With Peugeot Planet | Tom85 | 3 | 3,462 |
22-06-2017, 08:08 PM Last Post: Tom85 |
| Help with brake bleeding | Iaitoo | 18 | 8,082 |
10-06-2016, 06:06 PM Last Post: Poodle |
| Bleeding abs pump. | bashbarnard | 14 | 8,854 |
24-05-2015, 06:48 PM Last Post: Toms306 |
