Key blade cut over the net
Hi,
Does anyone know if you can get a key blade cut over the net, I just need the blade as I have a RCL fob spare. I have the code that tells them the shape it needs to be.
you can order them from pug. Not sure on the price though
(12-02-2013, 10:22 PM)DeeTurbo Wrote: Hi,
no you can't but if you dare post it to me i can cut you a copy . .Smile
(12-02-2013, 10:24 PM)Niall Wrote: you can order them from pug. Not sure on the price though
That give me the idea to check service box and it's £15.44 for a cut blade (992681), £10.41 for just a uncut blade. That's not too bad as I've seen places charge £20 for a key without the remote.
(12-02-2013, 10:27 PM)Mattcheese31 Wrote: no you can't but if you dare post it to me i can cut you a copy . .Smile
What cut a blade that will go into my spare fob? How much would that be?
well it'd be your risk that the Royal fail wouldn't lose it so if you only have one i wouldn't do it, could do you one cut for a tenner though posted
http://www.keysinthepost.com/
Used them before for my A3, just send them photos. I used them because it's difficult to find places that cut that type. Worked spot on, good service
(12-02-2013, 11:01 PM)Curt Wrote: http://www.keysinthepost.com/
i'd doubt they'd be able to do a pug key from a picture, i work in a key cutters, i can do ford and jag from sight but no others . . . .Smile
I got 2 blades cut for my dturbo for less than a fiver... They did that from sight as did I f*ck still have to key code lol
(12-02-2013, 11:41 PM)Connor Wrote: I got 2 blades cut for my dturbo for less than a fiver... They did that from sight as did I f*ck still have to key code lol
you're telling me they cut them without a key to copy from? . . . Confused
No, they had my key, but is that not what you mean by eye? Or do you have machines that simply follow the contours of the current key?
(13-02-2013, 12:48 AM)Connor Wrote: No, they had my key, but is that not what you mean by eye? Or do you have machines that simply follow the contours of the current key?
yes to the last bit no to the first bit . . .. .if you show me a ford key i can figure out the code just by looking at it (only coz i'm a clever bastard) most people can't but the pug keys you need the original to copy from . .Smile
Niall, you've seen how won away my key is! Would it be possible to get a new one cut? I've got all my codes etc..
