24-01-2012, 06:04 PM
Just noticed that there are 4 different water pumps, how do i know what one is for a D8a
Different water pumps
24-01-2012, 06:16 PM
i dont have a reg of a car with a d8a, my car was a dhy orignaly
24-01-2012, 06:23 PM
Hm all the xud ones are the same...infact all the XU ones fit each others....some are plastic / some are metal though.....not sure why there wuld be four different ones listed...
| #DervMafia | ![]()
24-01-2012, 06:28 PM
service box says they range from DIAM(diameter i think) 70 to 71.5, the one i have fitted to mine has two gaskets behind it a it was touching on the block when i tightened the bolts up?
24-01-2012, 06:30 PM
i had this happen to one that had done less than 50 miles
24-01-2012, 07:12 PM
Hm, there may well be differeances that im not aware of then.....The casting is certainly the same as ive ran S16 pumps on mine before etc...
| #DervMafia | ![]()
10-02-2012, 09:17 PM
Was there any reason for trying other pumps? anyone know a reg for a 306 that was original fitted with a D8a? want to go into peugeot with it and ask them why there is 4 types and one i need
10-02-2012, 11:01 PM
Just use any? My old one was N967 WJW if you want to use that?
12-02-2012, 08:15 PM
That will do, il go in when i get a chance
| FAI Water Pumps | RAW | 12 | 10,182 |
18-02-2015, 12:13 AM Last Post: vinny |
| "Cheap" new water pumps (£15) | silverzx | 22 | 15,614 |
11-04-2014, 05:36 PM Last Post: ConorTRG |
| What pumps are these? | bobertmate | 8 | 5,525 |
16-01-2014, 11:54 PM Last Post: Mal |
