What pumps are these?
Hello people, just seeing if anyone can shed some light. Went to the breakers today looking for bits for my mates 306 Dturbo S and saw a K plate Peugeot 405 and an S plate Citroen Xantia, both 1.9 XUD but had different pumps, i know the 405 one was definitely a Bosch i'm guessing 9mm? And the Xantia had a slightly different one, which i haven't seen before as i only knew of the Bosch and Lucas differences..
These are the pictures..
K reg 405
Pump
[Image: 1974_zps16efc059.jpg]
Bay..
[Image: 1975_zps028db08f.jpg]
S reg Xantia
Pump
[Image: 1972_zps29f927d5.jpg]
Bay..
[Image: 1973_zpsa77b6c5e.jpg]
Firstly which pump is the better one of the two, and secondly what are the differences between the them?
Thanks in advance.
semi-ecu pump i think
the xantia is semi ecu controlled and no good for a 306
the 405 one is a normal bosch pump and that will work fine on a 306
Team Doesn't own a 306
Yep grab the 405 one it will work fine
Both bosch but the xantia one is semi ecu controlled so go for 405 one
the inlet off that xantia is worth taking too
pinch the air intake piping too down to the turbo, lots better than 306, that's what i have . .Smile
Thanks people, did wonder when I saw the little electrical plug lol
(14-01-2014, 08:19 PM)bobertmate Wrote: Thanks people, did wonder when I saw the little electrical plug lol
Potentiometer.... Great crack when it's rotated too far one way or another Sad
Xantia pump would have that gay armour too, pre 1998 they didn't fill in the screws (thank fook mine was a 1997 pump!!!)
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
  FAI Water Pumps RAW 12 10,100 18-02-2015, 12:13 AM
Last Post: vinny
  "Cheap" new water pumps (£15) silverzx 22 15,515 11-04-2014, 05:36 PM
Last Post: ConorTRG
  1.5 derv fuel pumps procta 24 18,464 29-11-2013, 06:15 PM
Last Post: procta
