Dump valve help
As it says need some help with my dump valve. I've got a baileys dump valve set up that's been on my last two d turbos and working great but blew my engine up a few months ago and since the new engine fitted it won't hold down the pressure under boost so had to lock it wright down so won't open at all and disconnect the pipe work.
Would it be the spring inside f**ked do won't hold pressure or not defo confussed me this time
If I shut the valve down so hardly opens at all it sort of works fine it releases but u can hardly hear it and doesn't let that much pressure out so help needed plzz
doubt youl find much info about dump valves on here mate, best way to fix it is to take it off Big Grin
^^+1 lols
Take it off!!! Doesnt do anything just makes a stupid sound wind the boost up and hear the wastegate!
Ok did think about that anyway the novelty gone off abit now first think I did really when first had a turbo car lol
has been said...but rip off that waste of money!!!!
  Dump valve on a diesel? 306pc 14 7,565 29-07-2014, 04:34 PM
Last Post: ADV_93
  dump valve leaking oil DTurboTom 41 17,726 31-12-2013, 08:40 AM
Last Post: Chris_90
  fitted a dump valve now lossing boost ingham66 uk 9 5,282 15-06-2013, 11:23 AM
Last Post: Piggy
