Fitting Buckets - Airbag Resistors
Evening all,
I'm planning on fitting buckets on the weekend, but could really do without the airbag light blinking at me all the time. Can anyone advise what resistor I will need to fit to the underseat wiring for the seat side airbags, and for the seatbelt pretensioners?
Any links to suitable ones with the right resistance it would be much appreciated!
Cheers
This info would also be useful to me also ninja
I've already told you you f*cking flid!
I know, but as I can't find any suitable ones I was hoping helpful chaps such as yourself would post links to suitable ones in here Smile
(05-02-2013, 09:08 PM)Niall Wrote: I've already told you you f*cking flid!
What is the score with this the niall? plug and play?
I used a 1.8 ohm resistor off ebay
Btw ed, I've a f*ck ton of resistors at hone, so I'm sure ill one suitable
Yep 1.8-2.0ohm resistor fused. Job done.
I'll need 4 annoyingly, 2 for the seatbelt pretensioners, and 2 for the side airbags. I think they're 1.8-2ohms from what Niall's said... if you could bring some up Sunday it would be awesome man Big Grin
Cool, remind me and ill stick my box of tricks in my box of tricks Wink
Maplin have everything you need, i went in and told him i needed 2ohm resistors fuse and he sorted me with everything, fuses, holders, resistors, came to under a tenner and i think i got six of everything and a 10 pack of fuses or something like that. Havent bothered to fit any of it yet though
I got some of eBay in a pack, but I've lost it since!
  buckets connorp 2 2,153 09-06-2015, 12:25 PM
Last Post: connorp
  Can normal seat belts be used with buckets? Ricky 19 9,450 29-11-2012, 09:13 AM
Last Post: declantg
