Ice help
Ice help
Bought a 15 inch Sony sub the other day 1400 watts peak anyone know what's the smallest amp I can use and still keep sound quality
What exact sub is it 1400watt is its peak so you don't want to be running it around there constantly do you have any more info on the sub
(04-02-2013, 10:14 PM)Willo Wrote: What exact sub is it 1400watt is its peak so you don't want to be running it around there constantly do you have any more info on the sub
15 inch Sony xplod
Ahh 1 one of those I had 2 of these in 12 inch few years back
Specs are
XS-L156P5: Size (inch)
15
Dual Voice Coil
NO
General Specifications:
Peak Power, IEC 268-5 (W)
1500
Rated Power, IEC 268-5 (W)
450
Impedance (ohm)
4
So I would say running just 1 a mono block amp at a rating of either 4-600 watt should see you getting some decent lows from it your rms rating will be around about 450 rms so a 600 watt mono is sort of your top end
Correct me if I'm wrong
I would not run more then 300Wrms into that i would use a monoblock such as a AlpineMRP-M350 or Vibe Slick Bass 1 or see if you can find an old school amp that would give that figure bridged?
