Electrical cable question
What cable do I need to sort my door looms out I know I need insulated single core copper cable but what width by this I mean
0.5mm
1.0mm
Etc etc
1.0 Mm multi strand cable. Single strand will snap
The stuff I've found is single core multi strand cable is that what I need ?? Sounds right don't it
(01-02-2013, 01:14 PM)Willo Wrote: The stuff I've found is single core multi strand cable is that what I need ?? Sounds right don't it
Correct Smile
Thank you for the quick answer and advice
what niall said, multicore is also easier to solder Smile
on that note, when your soldering, before you insulate the wire up again, be sure to clean the flux residue from your solder joint as flux will corrode solder weakening the joint, eventually it will break again if you don't.
nailvarnish remover and a cotton bud is ideal way to remove flux
Thanks for the tip mate ill do that
Is it just on the bit I solder or the surrounding area ?
  Electrical woes bashbarnard 13 7,120 06-06-2017, 11:16 AM
Last Post: bashbarnard
  Electrical help!!! Pompey306mark 7 4,306 16-08-2014, 04:47 PM
Last Post: Pompey306mark
Rainbow I got a electrical problem tomosy10 9 5,377 19-03-2014, 12:29 PM
Last Post: Razorback_Rob
