Too much timing?
Too much timing?
http://www.youtube.com/watch?v=4VNPKookJ...e=youtu.be
Soooo, when off boost the pump makes some strange noise. When on boost the sound stops. What could be the problem? Tried retarding the timing a little but does the same.
Simple solution. Always be on boost Big Grin
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
If that's defiantly coming from the pump, I really wouldn't start it again until you sort it.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
It's been doing so since it was rebuild 2 weeks ago.
Sure its the pump? Just sounds like a vibration to me lol
No no. It's the pump/injectors. When it rev to 2500 you can hear that rattle.
Screwdriver on the pump, ear on the other end and rev, see what you hear Smile
Since u rebuilt the pump?
New 9mm head, seals, gov mod, grinded lda pin.
Attached Files Thumbnail(s)
Has a spring fell out when u put the head in, I wud remove and have alook in
Lol that sounds epic!! haha love advance like that (although will kill your block long term!!) Does sound like your fuel timing though... knock your pump right back and see if it changes tone - if not it'll be something else.
